I have a 2014 Jetta 1.8 TSI (3rd gen EA888 DI engine) at 108k miles, no current oil leaks / PCV issues / codes - just the expected topping off of oil every now and then due to some burning. I've read a lot into the PCV issues on these cars - how they often fail at lower miles than me and can blow the rear main seal, and not to rule out swapping it out at some point as preventative maintenance.
I had a long discussion with the parts guy at the dealer - he seemed to know his stuff and highly recommended against changing it in my case as it could soon then cause seals to blow like at the timing cover or front/rear main as they'll be under more crankcase pressure once a new PCV is in place? And with the Genuine OEM part now costing at least $200, perhaps it's better to wait until it fails - could be years out as I only drive 10k miles/year. What do you think about this and what he said?
