Is the PCV Valve something that needs replaced regularly? Also; if the PCV valve becomes clogged or needs replacing will is cause a code or check engine light?
Reason for my questions: Having no issues with my cars but at their last service I received a recommendation that on each that I replace the PCV valve. When questioned I was told it was based on mileage not an actual test or diagnostic.
2008 Corolla; 73,000 miles, Pennzoil Platinum or Ultra synthetic every 5,000 miles since new.
2002 Toyota Echo, 127,000 miles, conventional 5w30 oil (Valvoline per the dealer) every 3,000 to 5,000 miles since new. PCV valve replaced once at about 80,000 miles so the one in it has been in for about 50,000 miles.
How about it: replace every x number of miles or wait until an issue or a maintenence code shows up?
