PCV and Low / High Oil Pressure
G'day mates.
What (if any) likelihood is there that a bad PCV would cause Low Oil Pressure in an normally aspirated engine?
(Generally speaking, not specific to any particular engine)
What are your thoughts / experiences?
Found this explanation at LS1Tech.com
Can PCV malfunction cause low oil pressure?
Ideally you want a little vacuum in there. The pcv normally does this. If you remove the pcv, and use a breather, then any pressure that builds up just goes out through the breather. You never see any vacuum then, if the pcv is removed. But you may get some blowby and oil coming out of the breather and getting on the engine or firewall.
The reason it affects the oil pressure, is because the oil is constantly escaping out of the bearings. If you had 40psi of oil pressure at regular atmospheric pressure inside the engine, for example, and then somehow you could pressurize the inside of the engine to 40psi, theoretically the oil couldn't get out because the pressures would be equal, with the air pressure trying to hold the oil back. But the oil pump would still be pumping, so the oil pressure would continue to build up until the oil started getting out again. And if you have a vacuum in the engine, it is trying to suck the oil right out of the bearings, so the oil pressure is less in that case.
The old rule of thumb for oil pressure was 10psi per 1000 rpms, to protect the bearings. I don't know if that rule bends a little for the LS1 engine or not... As long as your oil pressure is within factory specs, I'd say don't worry about it varying with or without the pcv connected.
(a plus of having a little vacuum in the crankcase, is less resistance seen by the backside of the pistons, and a little less air friction seen by the crank) At 4" away from crank centerline, when turning 6000 rpms, things are moving at over 209 feet per second, or 143 mph....
the oil pressure or vacuum also acts on th oil in the sump, pushing or pulling on the oil going up the pickup tube. the oil pump will pressure to a certain psi above the pressure in the engine crankcase, limited by the bypass valve (that also has the vauum or pressure acting on it.
This somewhat contradicts the post from LS1Tech since his (or her) post only mentions the pressure acting on the oil as it leaves the bearings but does not consider the force of the pressure acting on the oil in the sump. Seems to me the pressure on the oil in the sump would significantly exceed the pressure against the oil coming out the bearings? And IF that was the case, higher crankcase pressures would result in higher oil pressures? Maybe they balance and cancel each other out?
(His assertion being greater crankcase pressure = lower oil pressure...or did he mean "lower oil FLOW")
But even if his assertion was correct, wouldn't that mean the indicated oil pressures would be higher at the oil pressure sensor port since the pump would be working against the resistance the oil is encountering as it exits the bearings?
Great point you make.
OK,
So to test the theory I went and fully heated up the vehicle and drove it 5 miles and noted the engine temps and oil pressure at various RPMs and speeds.
Then I stopped and removed the oil cap and then drove another 10 miles.
I noted absolutely no difference in the oil pressure or engine temperature.
0% of a bad PCv effecting the oil pressure . They are not related or connected
Ya know, no matter what answer or opinion you endorse, you'll find it on the Internet.
:cool:
Did you see that post above from LS1Tech? I've also seen many times during my Google search.
Personally, I went into it agreeing with you.....and it made ZERO diff.
