Parents have never changed coolant
I was just thinking about this a few days ago. My parents have three vehicles and none of them have ever had the coolant changed. The oldest is a 2002 an 05, and an 06. Now the 06 only has 10,000 miles on it and the other two vehicles have around 40,000 miles. Does this mean that one day a hole is going to corrode through one of the cylinder walls? The 2002 model is a mercedes so i'm not sure how often you change the coolant on that one. I've told my dad about changing the coolant but he's like well if we lived up north i'd be more worried about it. Then he got kind of mad when I tried explaining that it prevents corrosion too so I left it at that. He's good about changing the oil but that's about all he does.
A drain and fill is pretty easy, can be done at the base of the radiator, usually a plug that's only hand tight. 5 years/50k is about right. Use factory fluids only, never mix.
In addition to freezing or overheating, the risks are corrosion throughout the entire system (waterpumps, coolant lines, etc). And the engine does run better!
I still have the same coolant in my cav (dex) that it had back in 2004. Granted, the car had less than 40k on it. Still looks good too...
It wouldn't hurt to change it, but unless they are planning a long trip I wouldn't sweat it too much yet.
They don't really have many miles just a lot of time on the coolant. I already warned them so i'm just wondering if the block is going to get corroded through one day or if the water pump impeller is going to have the fins corroded off where it doesn't pump anymore.
My MB E430 is either 3 or 4 years on coolant, I need to check the owner manual, I did change the coolant last year with Zerex G-05, then it had a crack on the plastic part of the radiator, most coolant was drained to replace the radiator, so 1.2-1.3 gallons G-05 and same amount of filtered water in the coolant system now.
My 2004 S2000 has original coolant, the first change is 10 years.
I think as long as the coolant looks good and there are no signs of corrosion I would give them a simple drain and fill. The lubricants and anti-corrosion additves are either not there or pretty weak at this point.
Originally Posted By: Boss302fan
I would do a radiator drain and fill to get some fresh coolant additives into the system...
What he said haha
In my Chrysler, the antifreeze has to be replaced every 60,000 miles or 5 years. Which ever comes first. My car will be 5 years old next year so I will drain it out and fill it back up with Mopar coolant.
In order for the block to get corroded through, assuming it's iron, it would have to sit in open elements for a couple of decades, if not more, so don't lose sleep over corrosion.
Since your dad is against changing the coolant, just buy some of those coolant test strips and check if the coolant is OK. If the test strip shows that the coolant needs changing, just show it to him, maybe that will convince him, although I doubt that the coolant is in bad shape from just sitting around and with so little miles.
No need to worry about the block, but I'd be concerned about the rad and heater core. I'd definitely do a least one drain 'n fill on all three vehicles.
just once or 3 to 4 times?
After lunch with a G team engineer from GM, we now change the coolant only after component failure. I still have an 05 that has never been touched, but normally we put nearly 200k miles on them before something quits and we need to open the system.
Dex is that good.
Dex is that good.
+1 hallelujah!
Dex is that good.
But, if the coolant was changed more frequently, would some of those component failures be adverted? Keep in mind that GM is in the business of selling parts as well as selling replacement vehicles.
Madman, ask your dad if you can test the corrosion inhibitors in his oldest vehicle. Explain that when the inhibitors are depleted they allow electrolysis to eat away the metal. Show him the test with a voltmeter, and explain how 0.3 volts DC is the maximum allowable. It isn't about freezing, it is about corrosion.
Dex is that good.
My mechanic is not a fan of Dex Cool. My mechanic said it does get old and starts to gum up. I have a 2003 Chevy Cavalier that originally had Dex Cool in it from the factory and I do agree with my mechanic's opinion that Dex Cool actually does start to gum up when it gets old. My mechanic recommends to switch a car using Dex Cool over to the Prestone green antifreeze. I have a couple of close friends who have said their mechanics have said the same thing about Dex Cool and those mechanics prefer the tried and true green antifreeze. My personal opinion is completely flush your cooling system properly, refill with the proper antifreeze of your choice and replace the radiator and or coolant overflow caps with brand new caps from the dealer. New caps prevent problems and save engines! I have had radiator caps go bad. I have had caps bought from the local auto parts store not fit properly, so I buy these items from the GM dealer. The GM parts always work properly. Here is a quote from http://www.sancarlosradiator.com/dex-cool.htm :
"General Motors introduced Dex-Cool to certain lines of vehicles in 1996. Since it was formulated without the addition of silicates (the corrosion inhibitors in green antifreeze) a different corrosion inhibitor strategy was needed. Organic Acid Technology or OAT is the inhibitor part of dex-cool. Unfortunately, the dex-cool is capable a rather nasty breakdown. The residue it leaves behind is very sticky, and likes to find areas in the engine and other areas to "drop out" or "fall out " of solution and stick to the wall surface of engine and radiator. If the residue is in the radiator, hoses, or recovery bottle, it's relatively easy to clean and remove the debris. When the residue is in the heads and block, only a chemical flush will remove this orange mud. In some cases, the orange mud hardens, and seems to expand or push the gasketed surfaces out of position, causing leaks.
2002 Cad
No mileage claim here.
There are some in the industry (including GM) that claim that exposure to "air" causes the Dex-cool to come apart, and that faulty radiator cap design is the culprit. They say that with a faulty cap, the cooling systems allow evaporation, allowing the Dex-cool to destabilize, weaken, and lose it's already marginal protection, and then turn muddy. Others say that poor cylinder head design traps air in pockets, allows condensation and ultimately dilution, resulting in aluminum oxide formation and deposits. Neither of these theories completely explain the whole picture, and these are not a universally shared opinions. If air were the culprit, all Dex-cool systems in every vehicle with a recovery (overflow) container would suffer the same problem. They don't. Reverse flow V-8's would be immune. They aren't.
Most insulting about the whole issue is the GM dealer response to the problem. While the vehicle is still in warranty - turn a blind eye. Yet once the vehicle has gone past the warranty period, the solution is simple: replace the radiator, hoses, intake manifold gaskets and maybe the water pump. I believe it is this response that has spawned the current class action litigation.
There are about 72 brands of coolant on the market today. 95% of all these coolants are manufactured using ethylene glycol and mixed with 50% water when installed in a car or truck. Dex-cool is no exception. The differences between coolant brands comes from the additives that enhance the corrosion protection properties. For years this protection came from silicates, but more recently coolant manufactures have moved away from silicate enhanced coolant, to OAT enhanced coolant. Silicates are discussed more here.
Organic Acid Technology refers to the type of corrosion and rust inhibitors used in the make up of the coolant. OAT formulated coolants provide "background" or reserve protection (works like a vitamin), and as such, tend to react more slowly to situation changes as opposed to the faster acting silicates (works like an aspirin). There are several ingredients that constitute the OAT, including carboxyl, benzoate, borate, triazole, and 2-ethylhexanoic acid. Depending on the brand of coolant, these ingredients may vary. Vehicle manufactures increasingly are moving to OAT coolant, and may have slightly different formulations for different markets. European vehicles have used OAT formulated coolant with an addition of some low level silicates to provide further and faster protection. These are called hybrid inhibitor coolants because they contain both silicates, and OAT formulations. More discussion on coolant, inhibitors, and silicates are discussed here.
Dex-cool manufactures continue to insist that Dex-cool will last 5 years and 150,000 miles, and that the problem is lack of maintenance. In other words, you should be maintaining your maintenance free cooling system."
^^^hey, all we can tell you is we have a fleet of GMC trucks, and we have no problems. Ever.
The whole Dex thing is a classic case of Internet Amplification.
Might want to ask yourself why Ford is using it now?
