Paper Cone filters
Katy, Texas
Where can I buy a paper cone filter for a "cold air intake" style of system. I would like to put a cold air intake back on my Jeep but don't want to use a K&N anymore. Thanks!
Any part numbers I can reference.... I'm sure that they all make the filters, I was looking for part numbers mainly... sorry I didn't clarify.
Without knowing what dimensions you are looking for...???
I could give you numbers for a BHAF guys use on CTDs, but it is probably a whole lot bigger than you really want...you got to be a little more specific...diameter, length, and flange size (and then someone might be able to help)?
Probably the best bet would be to stop at a local napa and look through their books...
steved
Try looking at OEM style filters. 98 Chevy pickups used a great big cylinder filter(11" long) that works great in some engine compartments. If you're more cramped for room, try a 02 Trailblazer filter. Remember the more area the better for flow. The reason K&N kits dyno higher sometimes is because they have more area and a better flowing hose.
-T
