Painting over anodized aluminum
Hi guys,
I was going to post this in the paint section....but it isn't automotive related.
I shoot target archery, and have an extremely red.....metallic and glossy bow riser.
Is it possibly to take shine off of anodizing relatively uniformly? Either mechanically or chemically?
Alternatively, I would paint it to tie me over until a powdercoating.
The replacement more modern version is around $450 so I'm considering playing around.
Otherwise I'll ignore the color and think about other things!
Anodizing it oxidizing the surface. I don't know why, but anodized aluminum in a saltwater setting - like a port, or in a steel mill, which is often full of nasty chemicals deteriorates the surface to a white powdery looking thing. So its possible, but I don't know what chemical to use.
Do you have access to a sandblaster? - a light sweep takes the gloss right off aluminum and would be an attractive finish as is, or as a paintable surface. A self etching primer (zinc chromate probably) would be the perfect base for paint.
PS Don't overdo it because sandblasting/bead blasting will go right through aluminum in a flash.
Thanks! I may actually. I have a friend with a small blaster setup. I wonder if a lighter medium might work.
Thanks for the replies guys, it gave me some things to think about
A light blasting medium should be fine but still avoid prolonged blasting. Better to take it out and do it again (even a couple of times) than overdo it.
I wear an N95 (paper) mask when I use a blasting cabinet (which should be okay without it). Silicosis is a serious problem and non silica blasting agents often have a small amount of silica in them, and if they don't start off that way they get contaminated with silica as they're used and re-used.
The nurse and I have most of the other volunteers at the aviation museum using N95 masks when they're using the blasting cabinet. And if it's not a blasting cabinet you need way more protection than that. There are no bonus points for taking a chance.
Thank you very much for this. I really appreciate it. I hope you don't have any lasting effects.
I may very well go this route.
