Originally Posted By: HKPolice
Wouldn't this filter be fully clogged @ 16k and running in bypass mode?
The PL14610 is the Purolator PureONE part number used on most Hondas. Keep in mind that Honda only recommends changing the filter at every other OCI. With the way that Honda's maintenance minder works, this could be over 30k miles on the filter! Here is Purolator's written warranty...
Purolator filters meet or exceed OEM (original equipment manufacturers) requirements and are tested in accordance with the Society of Automotive Engineers' test procedures. -
New car warranties remain in effect when Purolator filters are used in accordance to the engine manufacturer's change intervals.
In the event of an engine failure directly caused by a defective Purolator filter, which was properly installed and changed following the engine manufacturer's recommended service intervals, Purolator warrants that it will pay for the repair or, if necessary, replacement of an engine or other parts damaged as a result of any defect in any of our filters.
