Yes the code returned after replacing the thermostat.The engine running too cool can cause a rich condition. Have you verified the fuel trims or has the code returned since replacing the thermostat?
Been thinking about this some more and looking at the readings the O2 sensor is probably correct, it's voltage reading is as it should be and a fouled O2 sensor would under read rather than over read.I know the primary 02 sensor looks like its working - but that is the primary input into fuel trims. I might consider changing it before pulling injectors and such - more to rule it out than anything.
His Celica doesn't use this setup. This is the older generation.https://www.ebay.com/itm/2569650957...i7YxJbL9sxdEQteqv7rM-SEHJDJT4BWnMDM27BhLyqpxU
This is a picture (off ebay) of the fuel rail. I wonder if the vacuum module at the left of the fuel rail could be the culprit. Does anyone know what it does?
thats cool to know, but does that rule apply regardless of engine size? mine is 1.8L engine naturally aspirated, would the 1g/s per cylinder be the same on a 3L engine too?Those MAF numbers look low to me. Extremely rough rule of thumb is 1 g/s per cylinder per 1k RPM, so you'd want to see 4 g/s @ 1k RPM, 8 g/s @ 2k, 12 g/s @ 3k RPM and so on. Might be worth a good clean, regardless.
I have always been told 1g/s per liter at idle.thats cool to know, but does that rule apply regardless of engine size? mine is 1.8L engine naturally aspirated, would the 1g/s per cylinder be the same on a 3L engine too?
Completely agree. The numbers I gave were what I would roughly look for in park/neutral, engine unloaded.I have always been told 1g/s per liter at idle.
For example my 4 liter pulls around 4 g/s pretty consistently. My 2.5 pulls about 2.5. Give or take - altitude obviously has an affect.
I don't think there is a way to track by RPM - because air is based on loading as well as rpm.
Shouldn't my 1.8L be pulling 1.8g/s at idle then? but my reading is 2.7g/s so it's over reading?I have always been told 1g/s per liter at idle.
It actually goes both ways - can be lean or rich both banks. Without known good data, it would be hard to interpret.Also with my experience of maf sensors when they are on their way out they tend to under read rather than over read resulting in a lean condition.
Dunno if my car has one but could an egr valve cause this issue?
On the hot wire type like yours, you can clean them no problem. Just use the CRC MAF Sensor cleaner.Cool, just need someone who has a gen7 Celica 2zz to chime in with Their data.
Suppose I could clean the maf but too many posts say I can make it worse by cleaning so I'm a bit reluctant to go that route just yet
Looks fine to me.sounds like a job for the weekend. will see if i can get this CRC maf cleaner here in the UK.
would regular electrical contact cleaner work?
https://www.toolstation.com/holts-electrical-contact-cleaner-aerosol/pAE193
