Good evening - My 2003 Dodge Caravan lit the check engine light. I bought a 15 buck OBD Scanner at Walmart and it gave code P0135. I replaced the downstream O2 sensor and the check engine light is now out. I did disconnect the battery cable for safety while changing the sensor.
The OBD scanner now shows " no trouble codes "
Did I fix the problem or just temporarily reset the check engine light by disconnecting the battery?
Thank you in advance for any advice
