Oxygen sensor deposits (pics)
Viña del Mar, CHILE
Hi, I've just changed the oxygen sensor in my 99 Chevy S10. It was the original sensor with around 120k miles and I notice it has a white hard deposit in one side of the sensor. Anyone knows what that can be or if it means something?
Had you recently used any fuel injector cleaners, or any other fuel system or oil additives? Does it burn oil? Lose coolant? Which sensor was this?
It is the pre-cat sensor.
I've not used injector cleaners in a while (my guess is in 20k miles).
The truck doesn't burn oil, at least not noticeable. It uses around half a quart every 3k miles.
I check the coolant regularly and I don't notice a significant drop in the level.
Even before the picture loads on my dial up, I can tell you this is normal.
OK... there it is.
Absolutely normal. Some more, some less.
But at 120k it does not even warrant a yawn.
OK... there it is.
Good to know that it is normal. I saw other photos of used O2 sensors on the web and they looked different, that's why I needed to ask.
A question about your comment: what does "warrant a yawn" means? English isn't my first language, and I couldn't understand that expression.
Originally Posted By: shpankey
I don't know but you take awesome pics! That must be a cool camera.
Thank you! in this case the secret is to use the macro and the flash, even in broad daylight
Are you saying he doesn't possess skill? It was all camera?
"Warrant a yawn" means it isn't worth the energy you'd put into a yawn. no big deal.
