- Joined
- Sep 28, 2002
- Messages
- 39,799
Quote:
Sorry to sidetrack a bit here but what is the general consensus on using oversized oil filters? Less pressure at startup? Myth?
It's just over-reasoning. If all things are proportional, a larger/longer filter should offer you higher loading capacity, lower fluid velocity (which should increase efficiency) and less PSID on the occasions when one may encounter such things. Assuming the same media, one would have better filtration.
