Originally Posted By: Hootbro
What problem you solving by going over sized? Also, in the rare event you have a filter failure, the filter maker can deny warranty if your over size filter is not cataloged for your application.
2014 dart is probably out of warranty, so that is not an issue.
As for the "problem", some would like a little more oil capacity as well as a little more filter area, Neither of which are bad things if you are wanting to extend OCI, or just want to have a little extra.
If the filter spec's are the same (gasket, bypass pressure, has a ADV built in (or not)) I see no reason not to use a larger filter if it will fit and you choose to do so.
I have a few Bosch Distance Plus D3422 filters (PH3600 size) to use on the Scion once done with the CQ 84145 filters (OEM PH4386 size).
I would use a PH8A if it would fit (but gasket area is a bit too big, ~72 mm outer diameter, and oil filter mount is 70 mm).
