Oversized Filter P/N's please
South Texas
I would like to know the oversized P/N for filters for the following vehicles.
2001 Chevy Camaro 3.8
2000 Chevy Silverado 5.3 2wd
1995 K1500 350 4x4
Purolator and Wix please
Thank you!
Camaro
Part Number: 51036
UPC Number: 765809510364
Principal Application: GM Cars + Trucks (80-05), Mercruiser, Volvo-Penta
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 18X1.5 MM
By-Pass Valve Setting-PSI: None
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=12/26
Burst Pressure-PSI: 325
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 25
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
For the 5.3 my quick scan get nothing bigger- I'm sure that there is one
Same for the K 5.7 ..I find shorter options. They appear to spec the same filter as the bigger one for the 3.8 Camaro
