Oversized filter for 07 Suzuki SX4 (PH4967)
Kentucky
Looking for an oversized filter to fit the Suzuki SX4 2.0L DOHC motor. It's the same filter used on the Suzuki Aerio's as well as numerous other import cars, Nissans and such.
It's fram part number is PH4967, Purolator L14476, WIX 51056.
Any help would be greatly appreciated!
How big do you want to go? Got room for length and girth??? This is the most popular thread/gasket combo on the planet.
There are many more.
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Mercury (81-07), Chrysler/Jeep (02-07), Mazda Trucks (94-07)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=14/31
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 20
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=10/26
Nominal Micron Rating: 19
Gasket Diameters
Attached 2.834 2.462 0.200
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 270
Gasket Diameters
Well that's great news. This will be the first oil change, so I'll go stock size for the time being (fist OCI will likely be less than 2k). I'll have an idea after that just how big I can go. The engine has a rather large sump (~5 qt) for it's small size, so I'm not reaching for the sky, just something with slightly more volume for extended OCI if nothing else.
I appreciate the response, I'll cross reference those numbers on the Purolator website and see what they look like in the store.
Okay, I looked at the stock fitment, and there isn't much room for increased girth, perhaps another 1/4" diameter. Length on the other hand isn't a problem, I could easily go another few inches in length.
Does this bring about any specific filter suggesions?
The FL400S MC, 51516 Wix, PL20195/L20195 Purolator, EAO34 Amsoil
That would be where I'd start.
I did a little research, and Onan generators take a filter exactly like WIX 51056, except it is a 4.75" long. It has the same gasket seal, thread size and pitch, and internal parts. The only filter brands that make one though are Baldwin, Fleetgard, and WIX. All the other filters you guys listed will probably work, but in order to get an exact replica, you need to go with a Baldwin B7238, a Fleetgard LF16165, or a WIX 57398.
I just need some confirmation/affirmation, before trying out an oversized oil filter on the SX4. I've also volunteered to be the "oversized" guinea pig on the sx4club site. I am hoping someone else tries it before me though...
Will the Amsoil EaO34 (Wix #51516 / K&N HP-2009) work? Note the diameter difference between these filter sizes vs. stock...
The rest of the oil filter specs look correct, and there is plenty of room for a larger filter.
Most Toyotas use the ph4967. On my mom's Camry I sometimes run the ph3600 equivalent. It works fine and compared to the 4967, it is huge.
Thanks asiancivicmaniac.
It's the diameter that's causing me anxiety. I'll give it a go, and try to not let the 0.236 difference, freak me out!
Put it on and test it. You'll most likely be a max pressure at idle with fresh oil. Allow it to fully envelop the engine and rev it a bit. That should be the maximum pressure that the filter will ever see ..even when much colder. Beyond that, you're looking for seepage. That you can wait until the next OCI.
If anyone out there has the SX4 and wants to give this a try before my next OC... Please do!
This will be my first ever over-sized oil filter. On my very first ever, "brand new" car! What am I thinking?!
Oil Good-Times!
