My FIL 08 4.3 V6 Silverado with 59k has overheat indicator/AC disabled on. The hose from water pump is hot while radiator is cool to touch. Fans work. The temp gauge is stuck on C never rises driving.
I can’t find a radiator cap but maybe buried under plastic? The coolant overflow is at normal level. He’s 80 so he is fiddling with it in my driveway.
Advice ? If it had a cap I could see if has coolant.
