GON
$175 Site Donor 2026
The city water we have is very high in calcium and chlorine. The high calcium, mixed with the ever present brown sentiment from the open desert makes an awesome cement like product. This makes washing the brown sentiment off of walkways, porches, exterior walls, etc an impossible task.
Decided to install a seasonal outside water softener, separate from the inside the home water softener.
Hooked up to an outside spigot. Anytime I want untreated water, takes just a second to put the softener in bypass mode.
The challenge now is how to protect the softener from the desert heat/sun. I am also thinking the softener water is better for outside plants because the chlorine and calcium is removed. Many experts state to not use softener water for plants, I will be doing more research.
