Out of round tires
First, the purpose of making the wheel deliberately off center is so that - on the average - the tire wheel assembly will be rounder when they are matched up - high point to low point. So BOTH have to take place to jave the desired affect! The small amount of offset shifts the worst assemblies into an acceptable range while leaving the best assemblies within the "mud" of road vibrations - that is, undetectable.
To my knowledge EVERY vehicle manufacturer did this. They may be doing this today, because it is such a better way to deal with the issue. The ones I am sure about are GM, Ford, and Toyota.
The only issue is with replacement tires. But the offset is so small that the difference is like the difference between an "OK" ride and a "Good" one. It's not like "Bad" to "Good"!
Really, it's nothing to get worked up about. It been going on for over 40 years!
Goodness.
Practically no tire shop is going to do that. Especially the kids working at Discount Tire, Costco, etc these days which are the only places you can buy a tire anymore without being ripped off.
Vibration meter at 60 MPH shows a ~14Hz vibration as well as the 4th harmonic.
First, good on you for using a vibration meter.
But I think that 14 Hz and 42 Hz makes it a 3rd harmonic not a 4th, which would be 56 Hz.
It is not unusual for there to be excessive 4th harmonic vibrations due to tires, but not 3rds!
Vibration meter that's pretty cool! My bad luck continues.. what I thought was a balance issue on the Escape has to be a belt issue with one of the Firestone All Seasons which on the front now, that's a strange feel through the steering wheel. Only 3 years old not sure if I want to fight Firestone on it. Got a couple of used tires for the front of the Focus, not sure how long that thing will run, and one of those has radial pull. I'm about to drop a couple grand on Bridgestone Duelers.. or Michelins.. for all and be done with it. Doesn't bother my wife but I tend to get headaches easier from it.
OIP.Qz08b1I-k4ydW1jsD5uMIQHaFj
these tires are slightly out of round. :ROFLMAO:
Yeah, youre right. LOL... Dont know what was going through my mind, lol! Simple math. I think 4th harmonic came into my mind because I had assumed that maybe tires are made in quarters.
3x might relate to the 3.07:1 differential then.... So for every one turn of the tire, the driveshaft is spinning 3x. Maybe makes me think that the rest of the vibration is related to a 40 yo driveshaft with "lubed for life" components, versus the tires.
Honestly, Im surprised that the one roadforce balanced tire that came out at 34 lbs, barely shimmies my steering wheel at all. I can feel a vibration, but I cant figure what I am feeling, I had assumed tire... But maybe not at this point. The other tires seem to roll really smooth...
When I have time, I'll tell you about the time the company I worked for produced square(ish) tires.
On a side note: If that 34# tire didn't set off much of a vibration in the steering wheel, my best guess is that the vibration is elsewhere. The driveshaft seems like a good place to start!
OK, here's my Square Tire story: BTW, this happened several decades ago.
This is going to require some technical background.
When you look at the tread on a tire, you should notice that it repeats itself. You should also notice that the repeated elements aren’t all the same size. We call those elements “pitches” and the pattern the “pitch sequence”. It’s there to spread the noise and vibrations over a frequency range, rather than them all occurring at the same frequency. Spreading it over a range makes it harder to discern from the background noise/vibration.
I got a call from Ford that they needed some help understanding a problem they discovered. After a great deal of work, they had isolated the problem down to a vibration in their full size cargo vans, with diesel V8’s, with lockup transmissions, and 4.10 rear axles AND our tires at 42 mph when crowding the throttle (that means just pressing slightly on the accelerator pedal). Remove any one element and the problem wasn’t really there.
So we brought a team of vibration experts and FORD demonstrated the problem. Sitting on the floor of the van (No seats! It was a cargo van!), the unsupported side panels would vibrate like a kettle drum – and just as loud!! It would literally drive you insane with how loud it was.
They said they could do that with ANY set of our tires, but other makes/models didn’t do it at all. And of course, changing any of the other things also didn't produce the vibration.
To make a long story short, we were producing tires that had a high radial 4th harmonic because the pitch sequence sort of repeated itself every 90°. That 4th harmonic was combining with the 4 pulses per engine revolution (Worse on a diesel) and the lock up transmission, and the 4.10 gear ratio to produce a vibration that the side panels would naturally resonate at – and that occurred at 42 mph. Crowding the throttle made the engine pulses stronger without causing excessive vibrations in other frequencies, which disguised the problem.
Once we figured out about the 4th harmonic - and before we talked to Ford about it, our sales guy, who was one sharp cookie, realized we would lose business if we didn’t act quickly, so he had our engineers design molds with a pitch sequence that was more random, got the molds delivered in 60 days. and by the time we could sort this all out with Ford, we were delivering the new product. He also instituted a policy that if any consumer complained of such a vibration, we would overnight FedEx a set of tires from the new production to the consumer’s nearest dealer and exchange old for new free of charge.
Crisis averted!
To this day, I am amazed the sales guy anticipated the problems that the company was going to get into and figured out a way to fix them BEFORE they actually became problems! He eventually became a VP.
Now some of you may be aware that changing an OE part requires a re-qualification – and that takes time – AND – changing an OE part without informing the vehicle manufacturer is likely to get you disqualified from supplying ANY parts. EXCEPT that you are allowed to change certain things that aren’t covered by the qualification testing, and this pitch sequence thing was one of them. We gave several sets of tires to Ford for their testing and not only was the problem solved, but the new tires performed exactly like the old ones.
