Originally Posted By: Tanama
So apparently Zerex overplayed their claims with the "Traditional Green Coolant". Now, with a low silicate formulation, their corrosion protection capability is probably somewhat limited; but probably less chances for drop-out or solids suspension in the long run. Their coolant line-up is usually very good, but a little expensive.
Let me add, it is my understanding that any glycol based coolant manufacturer claiming to exceed the 5 yr/100,000 mi mark might be pushing its claim. At those usage levels, the glycols are prone to decomposition in to acidic by-products. Then, IAT, OAT, nor HOAT corrosion protection packages will be able to protect much. Now, for diesel engine coolants with SCAs, that might be different.
In most cases, anything above 100,000 mi might be a true overkill for most passenger vehicles. Then, a timing belt or water pump replacement might be in order, and the coolant has to come out.
Tanama,rite on you made my point for me quite eloquently I might add!!!!Plus I can get the green at my favorite price (for free) yet some of the high milage oat stuff can be as high as 45 dollars a gallon before shipping and handling!!!yikes!!!Plus if 100k can be done with original green then Peak and the rest of the green makers would jump on the band wagon!!They would have it printed on their respective bottles in glow in the dark paint!!!I would guess their bottles would say 125k!!For me long live original green!!!
