I know they changed these at some point, but does anyone know what the current orifice size in the bypass filter heads? I want to make sure I have the right size before I install a recently acquired head.
I have one I bought a couple years ago and was working on installing this evening. I don't have the filter on yet so I might be able to measure it using drill bits.
The one I installed on my Jeep WK has an .032" orifice.
.032" flows .156 gallon per minute of water at 40 psi. Not sure how that translates to oil, probably less. With the Ea-110 bypass element, my total capacity is 3 gallons. So the whole amount would take about 20 minutes to pass through that orifice. And if I recall correctly, Amsoil claims that their bypass systems typically filter all the oil about 3 times per hour.
