Oregon Blade Ruler
North Carolina
I bought this to try when I stalling new blades.
I love it.
It's so much easier to level the deck side to side and front to back. As long as you are on a level surface, with the tires evenly inflated.
You can also check for bent blades without removing, check the inside cutting edge of the blade, then the outside cutting edge.
I adjusted the front of the deck a bit over 1/4 inch lower than the rear of the deck.
For $10 it's a time saver!
https://www.amazon.com/dp/B00TM8WJM8?psc=1&ref=ppx_yo2ov_dt_b_product_details
very handy tool. I use one for my JD LT150 every spring. Like OP said the key is to make sure the tires are properly inflated then start your measurements.
Just my $0.02
Just my $0.02
I bought new tires and switched types from a turf saver to a lug tire. Even though the stated size is the same, the back of the mower deck was 1/2 higher with the new tires. I had to raise the front of deck.
