Originally Posted By: Gary Allan
I wanted to touch back here for a bit.
Quote:
Wear at 50°C was extremely small due to significant reduction in the severity of contacts due to the increased film thickness resulting from increased oil viscosity. The wear rate under this condition was near zero. However, the wear rate increased when the oil temperature was raised to 100°C again.
Also, the friction torque decreased with increased speed at 100°C because the valvetrain operates in the mixed or EHD lubrication regime. However, at 50°C the friction torque variation with speed became flatter compared to that observed at 100°C. This is due to fewer mechanical interactions between asperities on two sliding surfaces due to increased oil viscosity.
This is exactly the opposite on the Schneider Cylinder/Ring wear paper. In that study, wear was highest when the engine was cold and evaporated as the engine warmed (visc obviously being lower). This is 180° out of that wear relationship.
Gary, I guess you did not read the methods carefully. The 1ZZ-FE paper studied radiotraced rings in a fired engine. The other paper used a motored valvetrain rig. As I pointed previously, the start up wear in ring/bore is mostly chemical/corrosive and that was observed indeed in the rings of fired engine. The valvetrain setup was free of combustion blow back and showed less friction and less wear with thicker oil as it can be expected in hydrodynamic lubrication (thick oil) vs boundary lubrication (thin oil).
So no, there are no discrepancies and engine wear is more complex that the usual thin/thick dispute.
