I haven't use the Opti-2 oil but I looked the other day (before I wrote my initial post, on the prev. page) at the oil's SDS and it shows:
Kinematic Viscosity: 13.4 cSt @ 100ºC; 101 cSt @ 40ºC
Page 5, Section 9, 2nd column, 2nd to last line
The PDF is from May 2025.
https://opti2-4.com/wp-content/uploads/2025/10/Opti-2-Two-Cycle-SDS-5-2025.pdf
Those are properties of a 40 grade oil, so I guess it's rather thicker than thinner oil. That's why it can be run at 72:1 similar to Amsoil Saber which people run 80:1 and 100:1. Other 2-stroke oils for both OPE and motorcycles are much thinner that that, with properties of a 30 and 20 grade oil. The last may cause major failure if run lower than 50:1 ratio. I know people who run ATF which is about 5 cSt @ 100ºC (very thin oil) but they run it at about 20:1 (25:1) ratio.
The most important when run 2-stroke oil is to know what upper rod bearing the engine uses -
needle rod bearing or just
a bushing bearing. Most of todays engines run needle bearings and are fine at 50:1 ratio or lower with thicker oil. However, older engines with bushing rod bearing should not be run on leaner than 25:1 ratios, regardless of the oil thickness.
