Torsen is a torque biasing unit that is almost transparent to most people. I sugest you look into it!! They are expensive and need premium synthetic gear lube with lots of additives but they rule for daily driveing and have almost taken over F1!
Are you sure John ?quote:
http://www.theoldone.com/components/quaife/quote:
The QUAIFE has been proven in everything from Pro Rally to Formula 1, but you don't have to be a pro to enjoy its benefits.
Ditto.quote:
Originally posted by T-Keith:
I'd always take an LSD over an open diff.
just the opposite. the torsen doesn't need anything special, not additive nor synthetic. The gear lube requirement is dictated by the ring/pinion gear in the differential. Zexel/torsen has a decent website with detailed info on the T2 type a, b, and T2R. I don't think the T2's are expensive, relatively speaking. The T2R's are expensive, over $500 I think for just the unit.quote:
Originally posted by JohnBrowning:
Torsen need premium synthetic gear lube with lots of additives
quote:
Put a full spool in the beamer and be done with it: least weight, most efficient, most HP.
Now THAT would be fun in the snow. NOT!
[qb] Put a full spool in the beamer and be done with it: least weight, most efficient, most HP.
I'm a little lost...What is a "full spool"?![]()
Snow tires are what it's all about. 4WD with summer tires is all but worthless in the snow. 2WD with snow tires will get you going.quote:
Originally posted by VaderSS:
I've never seen a vehicle that was worthless in light snow, if it had good snow tires on it...
