i want to open my oil filter and see what it caught...yet my dremel tool is broken can i use a saw blade that cuts metal?? how do i open it...what should i look for..i just chagned to bosch filter from fram so i want to see it =)..
I've used a hacksaw in the house with a ***well drained*** filter and a lot of newspapers to catch the filings. It didn't make too big of a mess or take too long. Nothing happened that made me regret doing it.
Have you guys seen the pipe-cutter versions? Very clean but it seemed like too complex a mousetrap, especially for the $70 one online source was asking.
I've used hand & powered saws, nibblers, and shears, but now stick to a die grinder. With proper finesse there's no visible debris added to the filter and the entire job takes
David
If you have a vise with good jaws you can simply hook the base lip into the vice and peel the lip away from the base plate and then pull the internals out. This is excellent if you don't want to contaminate your filter media with metal filings. It takes more time than the hacksaw method but gives a decent result.
Yea good idea. I just drill a hole in the bottom and let it drain for a few hours. I use a hacksaw and a vice. Just don't saw through the whole thing. Cut around the shell.
