Open Brake Fluid
Scituate MA
I opened and used brake fluid container (removed fluid and filled).
Can I use again? I thought I remember someone saying it is (yeah, big word of the day...had to look it up) hygroscopic - absorbs moisture but would that apply even with cap on?
Sure you can, put the cap on tight and keep it in a dry cool place, putting it in a ziplock bag is not a bad idea if its going to be longer than a few months.
Unless you live in a very dry climate like southern CA, NM or AZ, etc I would toss it at the 2 year mark.
I don't know how accurate the electronic brake fluid moisture detectors are but I tested the fluid in a plastic bottle that had been opened and re-capped for over four years and it still tested as being fine. I've never even thought about it in the past (my pre-BITOG days) and haven't had issues yet.
chuck it, especially if it's a plastic bottle.
If it's a metal can, it will probably be OK.
If you're just using cheap DOT 3, you can get a new bottle of that anywhere. Now if iot was something more premium and expensive, then I could see the point of using the remainder.
Once the cap is off, it pulls moisture from the open space in the bottle. I wouldn't worry about it, it's more important to change your fluid then worry about a little bit of moisture in the air in the bottle.
A half full bottle in a garage is better than a vented master cylinder in a car driving in weather and seeing heat cycles.
If the fluid's still clear/ amber, run it. At worst use it as a pre-flush when bleeding then finish with something new.
Wet brake fluid is better than no BF in a pinch, As long as it didn't freeze, it would be fine in a Hydraulic clutch. Also you could squish the bottle until the level was up even and put the top on. I use left over BF to set up airlocks when I bleed.
I have used previously opened (2-3 years) bottles of brake fluid and never had a problem. As long as it is tightly sealed, I wouldn't worry.
The way I look at it is the fluid in your car is vented to atmosphere via the reservoir cap. The fluid in your bottle or tin is sealed. Which is going to deteriorate quicker ?
The whole thing about throwing unused brake fluid away once opened is ridiculous. If it lasts 2 years in a car that regularly sees 99% relative humidity it's going to last more than 2 years in the tin on the shelf in my dry garage. I would and did choose a tin container over a plastic bottle.
