- Joined
- Sep 28, 2002
- Messages
- 39,793
Both have an ADBV and Ford spec's always include an open end valve placement. The differences are in the bypass valve setting.
Since I can get the most out of WIX. There's slight distinctions in terms of diameter and burst strength ..but the bypass setting is the big thing that sticks out with me
Part Number: 51315
UPC Number: 765809513150
Principal Application: Ford (98-04), Mazda (01-04)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.826
Outer Diameter Top: 2.983
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 320
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.750 2.400 0.130
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Lincoln/Mercury (81-08), Chrysler/Jeep (02-08), Mazda Trucks (94-07)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=14/31
Burst Pressure-PSI: 275
Nominal Micron Rating: 20
Gasket Diameters
Attached 2.734 2.430 0.226
Baldwin
Descriptions: Lube Spin-on
Contains: Anti-Drainback Valve
14 PSID By-Pass Valve
Front End Check Valve (this I read as specifying a open end ADBV. I've only seen ONE filter man, in Oz that ever promoted an "outlet side" oil retention mechanism to prevent filters "draining forward")
Fits: Ford, Mazda Automotive
Replaces: Ford F8CA-6731-AA
Thread: 3/4-16
O.D.: 2 29/32 (73.8)
Length: 4 27/32 (123.0)
I. Gskt.: [1] Included
UPC: 7 91440 05469 1
Descriptions: Full-Flow Lube Spin-on
8 PSID By-Pass Valve
Fits: Chrysler, Ford, Mazda, Toyota, Volkswagen Automotive, Light-Duty Trucks, Vans; Ford, Gehl, Kubota Equipment; Kohler, Onan Engines
Replaces: Ford E4FZ-6731-AB; Kohler 277233; Onan 122-0680
Thread: 3/4-16
O.D.: 3 (76.2)
I. Gskt.: G449-B
UPC: 7 91440 00304 0
Purolator has two different numbers ..but the apparent spec's are identical.
L20195
Type of Filter: Spin-on
Thread Pitch: UNF-2B
O.D.: 2.98
Threads: 3/4-16
Height: 4.74
Relief Valve P.S.I.: 12-15
L25230
Height: 4.74
Threads: 3/4-16
O.D.: 2.98
Part Number: 51315
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.826
Thread Size: 3/4-16
Gasket Diameters
Part Number: 51516
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Gasket Diameters
Baldwin
Thread: 3/4-16
Thread: 3/4-16
O.D.: 3 (76.2)
I. Gskt.: G449-B
L20195
O.D.: 2.98
Threads: 3/4-16
Height: 4.74
L25230
Height: 4.74
Threads: 3/4-16
O.D.: 2.98
