V-8 Mustang, I used Valvoline 5w30 conventional for the previous 3 oil changes and changed it at 5000 miles each time. This last change I used Castrol Edge 5w30, and it has used exactly 1 qt of oil in the firt 2500 miles, Car has less than 40,000 miles on it. Is this typical, will the usage stop, and why would the engine start to use oil when changing to a synthetic. I had thought the Edge was a great oil but I won't continue to use it if it makes the engine consume oil, I even think I might be able to see the engine smoke a little now on first start up.
