Originally Posted By: virginoil
Originally Posted By: Doog
Originally Posted By: sayjac
You still under warranty? Honda has a 1 year max recommendation regardless of MM%.
Likely fine, but under warranty I'd change it. Just me.
After warranty, your call.
+1 Me too. I never go past 1 year.
So if the OLM for Honda is 12 months max then why is OLM not saying to change the oil.
Is the OLM in need of repair or is the 12 months max OCI incorrect ?
What you're experiencing is normal. Our Fusion, if our driving conditions are right, will let the OLM go way over 10,000 miles. I think some owners have reported reaching 0% at over 14,000 miles. Like your Honda, our Ford's owner's manual says to not go over 10,000 mi / 1 year. But this only applies when under warranty. I figure they do this to somewhat save their rear end, in case by some chance some lubrication-related failure occurs while the powertrain is still warranted. Ideally though, outside of your warranty period, you could likely safely go the full term of the OLM, even if it takes 2 years to reach 0%.
