"older" Oil Filter Study @ minimopar
Everson WA - Pacific NW USA
I don't even have the link anymore (I don't think)....but I'm sure you guys are aware of the often copied oil filter study that ends up all over the web. Was originally (?) at minimopar, and he had a German oil filter section.
Is that still active? Did he ever cut into the Mann and the Amsoil filter?
Does the fellow lurk/post here?
This has seen some variations in various posts over the years. The original MiniMopar study was almost as negative about Champion Labs as Fram. The study Bob posted talks about rust, other comments were about poor paper quality. Supposedly some of this was cleaned out after threats by Champion Labs attorneys.
For the record, unlike Fram, Champion filters no longer appear rusty and the earlier paper "expert" who used to post on Edmunds (and was almost as expert an insider as Johnny is on these boards) strongly disagreed with the assessments of Champion Labs paper quality. I guess such charges are below the visibility line for the Fram folks
--but I guess you can't argue with marketing success.
I've also seen the expose from the Fram engineer linked on some of these variations of studies and missing in others. The North Texas Prelude study was largely duplicative of the Minimopar study--i.e. Fram is crap--http://ntpog.server101.com/reviews/filters/filters.shtml
quote:
Patman
Administrator
Member # 6
posted November 21, 2002 12:23 PM
I think the guy who did that page up probably ended up having some of Fram's hired goons after him!
Instead of the "Men in Black", they were the "Men in Orange".....
quote:
Where did you see the Fram "engineers" story? I'd love to see this...
Here's the text of the email Russ Knize received from an Allied Signal engineer:
Russell,
I obtained great satisfaction from reading your oil filter survey.
I worked for two years as the oil-filter production line engineer in
an Allied-Signal FRAM facility and I can confirm every bad thing you
have said about FRAM automotive filters. That's from the horse's
mouth, as it were.
I'm also a quality engineer and can confirm that FRAM applies no
quality control whatsoever to any of the characteristics for which we
buy oil filters. I frequently saw filter designs which were barely
capable of meeting J806. Many of FRAM's designs will block and go to
bypass after trying to filter very little contamination. There were
often leakage paths at the paper end discs when these were not
properly centered on the elements. Some designs had the pleats so
tightly packed against the center tube that they would block off in no
time. I had discovered that the FRAM HP1 that I had been buying for
about $20 Cdn was EXACTLY the same as a PH8 inside - the only
difference being a heavier can - no advantages in flow capacity. The
paper filtration media was of apparently poor quality and the process
of curing the paper resin was very inconsistent - elements would range
from visibly burnt to white. FRAM's marketers admitted that there was
just about no way the public could ever prove that an oil filter
contributed, or did not prevent, engine damage. The only thing FRAM
tested for was can burst strength. Another problem that they have from
time to time is in threading the filter base - often there are strands
of metal left behind on a poorly formed thread.
I have not used a FRAM filter since I started working there. Their
claims are entirely and completely marketing ********.
If people really want to protect their engines, a good air filter is
vital (which excludes FRAM from that list as well) and a combination
of one depth and one full-flow hydraulic filter, together in parallel,
will do the job of filtration to perfection.
Thanks for doing a great job in trying to get the truth out! You can
quote me anytime.
[name withheld]
If you go to http://minimopar.net/oilfilterstudy.html and scroll down to the Fram section, you'll find the link to this email.
