Old oil score!
U.S.A.
Yesterday was at my dads house changing the oil in his Farmall H that is a 1941 model; one of the last that had or was manufactured with rubber tires on it. Anyways, he gave me a ton of old Pennzoil oil in HD-40 grade, and cardboard cans say SC/SE I think for the API thing. I have about 7 quarts of this stuff. What should I do with it? I was thinking of mixing it in with some Pennzoil Conventional for my Chevy truck. Might mix some half and half with Rotella t5 10w30 I will put in the Cadillac. Also got 12 cardboard qts of EMBLEM (Now brad penn oil) thats hd-30, hd-40 and some 10w40
any advice is helpful
I wouldnt mix it with anything going into a "modern" vehicle.Keep it for an old Scout plow truck or forklift...
Sell it on Fleabay!
It would be intersting to do a sort run of this stuff in any car in warm weather and then UOA it.
I think everyone would be surprised at how good the results would be.
Alternatively, you could mix a quart at a time with any modern oil in any engine and it would be just fine.
I'd sell the staright grade oil to an air cooled VW owner or for lawnmower use.
You could mix it with a modern oil in warm weather, though.
Thanks guys, and think I will do that in the spring in either my Chevy truck or new to me Cadillac Coupe De Ville. I plan to mix it half and half with some T5 Rotella also.
thanks for the advice and opinions guys
adam
Pics or it didn't happen.
TPitcher, I dont have my digital camera on me and my phone does not have a camera on it. The oil is real as it says it used Z-7 additive in it.
adam
Yes, because the modern oil would be able to keep up and maintain clean the engine during a short run while the old oil degraded quickly.
IMO, using this oil is like using old pain killers: it may not hurt anything, but it for sure isn't helping anything, I.e., no money is saved, nor is there any net positive.
Keep it as a curiousity or sell it as a collectible, I'd not be dumping that into any engine I cared about.
adam
No prob. just razzin' ya...
Perhaps some other time.
It would be intersting to do a sort run of this stuff in any car in warm weather and then used oil analysis it.
Maybe not.
In a moderate performance engine, older spec oils can do just fine, just as they did when they were current spec oils.
There was a guy here who ran some old SF Shell Fire and Ice in his wife's Grand Am with a pretty good used oil analysis.
I've searched for the used oil analysis and have not succeeded in finding it.
A straight thirty or forty wouldn't be suitable for too many modern engines, although the OM of our Forester allows for the use of either under severe conditions, although the OM recommends API SL as the minimum spec.
Thanks fcdg and yes I remember that post. I dont think it would hurt to mix in a qt or so of the HD 40 Pennzoil or EMBLEM myself.
