Old Floor Jack
Kennett Square, PA
I have an old Alltrade floor jack, about 35 years old. It is Chinese made but an early model before they got real cheap. It is a beast, around 100lbs. Does not leak oil or leak down under load. But, every time I use it I wonder how much longer can this bad boy go before it has a major failure.
So, would you recommend replacing it? I am 76 and doing fewer and fewer big jobs. Maybe my old jack will last as long as I do?
I too am getting older and rarely need a floor jack, and just bought an aluminum one from Harbor Freight to replace my old, extremely heavy floor jack. The one I bought is less than half the weight.
I have an old Chinese jack that I bought back in the 90's. It developed a leak and after a bit of investigating I was able to get it working with a $1.49 O-Ring from Ace hardware. Paying $1.49 for a 22 cent O-Ring is a discussion for another day.
I say keep using it unless you just want a lighter aluminum one.
Weight does not bother me but I would enjoy low profile rapid lift Daytona Pro.
This 3 Ton Daytona Jack is a beast and worth every penny. I'd wait until HF has a sale on it (maybe Black Friday) and buy the color of your choice. I purchased mine in 2011 and have used it several time a week without any maintenance or repairs. The only thing that has worn out is the rubber cushion pad that sits in the cradle. Parts are available for it through HF online.
You don't have to lift that Jack you know just roll it around like it was meant to be. At 81 I still have my 30 year old Craftsman it works great but I'm not concerns how many deadlifts I can do with it!
I have a 2 ton and 2.5 ton alumnium floor jack. It makes a big difference, I'm done with scooting iron and steel around in my late 40s.
My garage has minimal floor space, so the big floor jack has been living in the shed out back. I guess I could just throw it in the Gorilla cart to bring around front, but the HF aluminum one fits on a shelf after removing the handle, which is a matter of unscrewing a knurled nut without any tools.
Just check the pivots under the saddle pad, my chinesium AL one had the leveler arm upper pivot pin fail from the C-clip falling off the end. I never noticed but they left almost no material after the grove and it bent over and failed... Nothing fell but not great for a simple engineering failure to occur.
My Chinese Torin steel 3T is a bit more robust but not crazy heavy.
I have the long-reach, low-profile of this jack and it's awesome. I agree with you completely! And the same part, the rubber pad in the saddle has come loose, other than that, it's been a perfect floor jack! love it! (y)
Daytona 3 Ton long reach low profile floor jack
The 3T Daytona Professional is on sale for $109. The Daytona 3T SuperDuty is on sale (for members) for $239. SuperDuty claims to have premium high quality seals. I don’t know what this means. I wonder if they are using u cup seals in the SuperDuty?
It doesn't specify the type of seals used in the literature; however, I would expect u-cup seals at this price point. Here is a link to the HF Daytona Jack Owner's Manual.
Should be using jack stands no matter how old the jack is.
My over 40 yr. old 1.5 ton Craftsman is still working like new. And its seen a ton of use especially back in my younger days keeping junkers running.
