I'm on several forums and FB pages for the 70's and 80's Mercedes, which primarily focuses on the W123 chassis and IDI diesel/turbo diesel engines. In a discussion about cooling system problems, several individuals are putting forth they believe the cars are designed for prolonged operation in the 100-110C range even though all the cars have 80C thermostats, stating that the red mark on the temp gauge isn't until 120C.
Having spent plenty of time in various cars using iron head/block gas engines that use a 190-195 thermostat and gauges that don't read red until around 260, I know iron engines can generally take a lot of heat abuse and survive unchanged. However, I don't see how it's desirable to continually run an engine, regulated at 176F (80C), up in the 230 degree range. Can anyone shed a more scientific/learned light on the matter?
