Old Car With Low Miles Going On A Long Trip
The only pressure that should be listed on the sidewall of the tire is the maximum operating pressure. Tell me you don't run your tires that high.
Of course not. 5PSI higher in the front, 4PSI rears than what's stated on the door card.
Nowhere near max pressure. I'll also adjust depending on the weight of the stuff I've got in the trunk and back seat etc. on road trips.
The recommended pressures on my car is for a soft forgiving ride and that's not how I drive.
If it were mine, I'd correct fluid levels and tire pressures; nothing more. I was gifted a 2005 Altima with less than 39k miles because it's "too old", and I would drive it SoFLo tomorrow with the same plan.
2009 is not that old. I’m currently on a much longer road trip (4 X 700) in a 2006 Honda Odyssey with 210K miles, still running some of the original coolant hoses. Would definitely check the hoses and belt(s), particularly if the vehicle resides in a hot region of the country.
And make sure that there’s no loose plastic body panels that could come loose (like I saw today in South Carolina)…. The dopes were driving past me with the bumper cover mostly attached, except for the right corner which was “catching air”, then later, the bumper tore back further. They were apparently oblivious to the fact that they were dragging plastic on I95 for at least 15 miles or so. Unfortunately, me and several other drivers had to follow these dupas for quite some time due to the traffic.
I would check fluids and tire pressure. As many have suggested, this is not that great a distance. When back, make a list of required maintenance items and do them.
Is the old rule of upping your tire pressure by 10% BEFORE HIGHWAY TRIPS a legit one?
Nobody mentioned the possibility of an ancient, excessively dirty battery or a 'low down' state of charge.
edit: Aged key fob batteries! And I wouldn't go near low-mileage spark plugs which may resist removal.
Yes, it will state the highest pressure that the MFGR says you should run. But, you can run any pressure UP to that maximum pressure. If you run say, 32 psi, which is an old rating that I don't think any vehicle recommends anymore, and your vehicle feel like it's dragging going around corners, adding a few psi will make it feel better and roll easier. The side benefit is better gas mileage, and better tire wear.,,
