Originally Posted By: rslifkin
It would make good cutting oil for drilling / tapping, or just a general purpose lube (like 3 in 1, as mentioned above). Or mix with acetone and use it as a penetrating oil (like the ATF / acetone mix). ATF and PS fluid are usually not drastically different, so it should work for that job.
Great ideas. I will just keep it as cutting oil.
