I'd use a full synthetic oil in a turbocharged automobile.
Agreed, with one exception. I would trust Schaeffers for lower pressure blowers at shorter intervals. It's also a super break in oil for turbos where a full synthetic is not desired.quote:
yes, I think you should be more concerned.quote:
Originally posted by gnef:
this is interesting. i have used the cheapest 5w30 on my STi... it is a 2.5L turbo. should i be more concerned? i do religious 3k OCI's though.
And what would you call proper cooling?quote:
Originally posted by BrianWC:
Oil coking isn't much of an issue in factory turbos with proper oil cooling. It can still happen but...
Break-in oil for a turbo? There's nothing in a turbo to wear-in like an engine. Maybe a BB one might have some actually bearing contact? Otherwise it's oil pressure that keeps the wheel/shaft centered.quote:
Nope. It's fine. STis are easy on oil. I wouldn't hesitate to run the oil for 5-7K if you fall under normal service.quote:
