What do you think the whole purpose of a PD oil pump is on an engine? It's to FORCE FEED the bearings. Modern high HP engines have to have FORCE FED journal bearings to make them handle the load and heat and last way longer than if they were not pressure fed.
Where do you think all that oil volume goes that leaves the PD oil pump? Do you think it's just circulates around and around in empty oil galleries and never goes through all the bearings?
How in the world do you explain what was happening in the video I posted a few pages back of the NON RUNNING engine being pressure fed oil, and all that oil was dripping out of every crank, rod and camshaft bearing at a significant flow?
You are so fixated on NON PRESSURIZED journal bearings that you are totally blind to what's really going on in a modern IC engine with a pressurized oiling system. As my mechanical design handbook clearly shows, there is a difference on how oil flows through a PRESSURE FED vs non pressure fed (ie, fed at atmospheric pressure) journal bearing. Yet you fail to believe it, or to even dig out your handbook (if you even have any), or do some Google searching like I suggested on pressure fed bearings to school yourself. You won't listen to me, so maybe you'll listen to what information is out there that reflects exactly what I've been saying.
You are so locked in and blind to what atmospheric fed bearing are all about that you can't understand the difference between them and pressure fed bearings. This is now just a waste.
