Oil viscosity testing
I posted this here for best visibility and feedback...
RP XRP 10W-40
1000hp Methanol injected 565 15:1 drag race engine
I'm pushing the interval this time and was messing around in the shop with a used sample (40 runs). It's pretty clean to the eye and with a drop on a paper towel.
I timed the time it take to drain a turkey baster of used and new oil, just as a simple test to see if it has been diluted or sheared out of grade. I did not measure any difference between the two. 50cc in about 25sec
Sample is on the way to Blackstone to be sure. With TBN
Has anyone ever messed around with this? Was wondering at room temp, if my little test would show a difference in some sheared or diluted oil? I did it at around 70F. Would be hard to do it at 150F normal temp.
Please understand my eng tune up is not like the typical and I do not have fuel in the oil as you may think. I use a 2nd gas fuel system to put heat in the eng so the injected meth is only when racing. Wide Band O2 is .85 lambda so it right!
Looking for feedback based on 1st hand knowledge on this as opposed to guessing thanks.
O and this is just about saving some cash and doing it with test data so it's safe and all.......
RP XRP 10W-40
