I have read a few times on this site that xw30 oils shear down to xw20 over time, and that xw20 is more stable. I also looked at the ranges for 100c temperature viscosity and found the following
xw20 5.6-9.3
xw30 9.3-12.5
I also read that mineral oils are "naturally" an x weight oil ie 5 or 10. Viscosity improvers are added to achieve the 20 or 30 or 40 at 100c and that over time these viscosity improvers are used up so the oil becomes progressively thinner at 100c.
Then I read that synthetic oils are "naturally" the 20 or 30 or 40 weight and something else is added to them so that they stay thinner at cooler temperatures.
Then I read that oil naturally thickens over time, especially mineral oils exposed to cold.
So please help me understand the following
1) Do only mineral oils thin over time due to loss of viscosity improvers or do synthetics do this as well. Ie is it true that if you buy a synthetic xw20 or xw30 that it is more likely to remain a 20 or 30 than the mineral oil because it has far less VI's in it.
2) Is it true that oils will thicken over time also? Is this true for both mineral and synthetic? If it is true, then is the rate of thickening faster or slower than the rate of thinning due to loss of viscosity improvers? Is it possible that a synthetic actually has a greater tendency to move away from it's initial viscosity due to it thickening but not having anything making it thin compared to a mineral oil which is thinning from loss of VI and thickening due to natural effects
3) The range for a xw20 is quite large. If Ford & Honda have spec'd 5w20, then does that mean it is safe to run something with a viscosity of 5.6 in it? Given that many of the engines are unchanged from those that were once spec'd as 5w30, then the possible range that the engine can run at is huge ie 5.6 to 12.5.
4) If oils do shear down, then for an engine that is spec'd as 5w20, would the best 100c viscosity to aim for be something in the middle of that range ie greater than 9 which means a heavy 5w20 or a light 5w30. In that case you would be certain that your viscosity would be always in the middle of the range for that engine design from fill to drain.
xw20 5.6-9.3
xw30 9.3-12.5
