Oil viscosity and VVT
OK
I've read and heard of a lot of issues with Toyota's VVT-i and Hyundai's CVVT which can rattle loudly on start up from stuck or broken gears in the VVT actuator. Now I've searched on here trying to find this out, but have come up empty so far.
I had thought that viscosity must be the answer to better VVT protection, but those two manufacturers recommend different weights (0W-20 for Toyota, 5W-20/30 and 10w30 for Hyundai). So now I'm looking at different additive packages and how that might help. When it comes to taking care of the VVT, would you be more concerned with the lower viscosity oil or do you look for certain additives in the viscosity of your choosing?
Sorry if this has been covered before, I couldn't find it if it has.
Regarding this specific issue, its more about fast oil flow than protection. Thinner oil (and cleaner) is better for VVT. Here's why. When the engine starts, oil flows down a narrow passage to the VVT actuator/controller. The pressure created by the flowing oil serves as hydraulics, unlocking a tiny pin that holds the actuator in place when the engine is off. If the flow is not good at startup, (dirty oil channel, use of thick oil, etc) there is a delay in flow. The actuator attempts to move, hammering on that pin prior to release. Once there is enough oil pressure to release the lock pin, approx 5-10 seconds, the noise disappears. This is referred to as the vvt startup rattle. Some manufacturers like Hyundai specify certain filters with good ADB to lessen the effects of a startup dry leading controller rattle.
So.. I would use a thin syn for best flow and keeping engine clean, change the oil on time (essential for vvt!), and a filter with a known good ADBV.
My Toyota Corolla VVT-I is more than 13.5 years old its had no issues yet. It has always been serviced within factory spec. It's been on Full Synthetic since 66K 5w30 and 10w30.
My xB has had Mobil 1 5W30 since the factory oil changes were used up (except for an ill-fated run of Mobil 1 Advanced Fuel Economy 0w30, which sheared by 7K), lately using Mobil 1 Extended Performance 5w30 for 10K changes, and I've never heard any VVT noises, it's now 12 1/2 years old and pushing 90K.
15W40 mineral for initial 110k miles , followed by 10W40 blend for 40k miles todate .....
Yota K3-VE engine VVT abslolutely no issues ...... as are it peers.
It's a myth that VVT requires thin oils.
Would think it’s engine specific … I have a pushrod VVT that does not mind 15w40 … heck, butt dyno likes Dino
Some DOHC set ups might be another story …
My ecoboost ran fine on 0w40’s …
Nothing you can do about startup other than insure you have a good ADBV and good flow. I had to try 4 different filters before I settled on what I'm using now. I think most noise is TCT anyway. Does not the ECM controlled VVT actuator remain locked at the porpoer position at idle and startup?
In the Nissan I have tailored viscosity to have the VVT in a good range to make torque where I want it. Lately that required a THINNING of Dexos1 5w30 down a tad with a litre of 5w20.
My Last year OIL darling - and still current darling - CASTROL MAGNATEC 5w30 Synthetic seems to keep EVERYTHING operating as designed. Current fill is Smooth, sweet, quiet and with good fuel mileage; much improved over the already dang good SS Magnatec I used last year.
Completely anecdotal, but when I used Pennzoil Ultra Platium 5w30 paired with a fram ultra last year, it was the quietest my 2azfe vvti engine was. However it got louder as the miles racked up. I've used dealer bulk with OEM filter , Quaker State Defy 10W30 with the Ultra filter (same filter as used with PUP), Mobil Super 5000 5w30 with a garbage proline/puro jobber filter, and now on BC Castrol EDGE 0W30 with a bosch D3421, Nothings quieter than the Pennzoil Ultra Platinum and Fram Ultra. On the other hand, the car consumed ultra like it was nothing. 3/4 of a quart in only 3k.
Again what I have stated is anecdotal, the engines got high miles and maybe fuel dilution plays a part in it. When I change ANY oil around 5k no gasoline smells in the oil. 6-7k is when no matter how hot I get the oil, it smells like gasoline. Since Pennzoil Ultra is hard to find and I have many other oils in the stash I'll keep trying something else until I find something that keeps the engine quiet and maybe another filter that eliminates start up rattle. I believe the Fram Ultra is as good as it's going to get, but I have some RP and Mobil 1 filters I'd like to try.
Is it blocked piston oil control return holes, valve seals, both?
I'm not sure. I've never had the consumption problem diagnosed. Many are oil burners so I know its normal to burn the amount mine does and even more for some. I think that lower visc oils like pup have higher consumption than say QS defy 10W30 (which took 4k to get to 1/2 qt). The BG 0w30 is the thickest I've run so far so we will see how much of it the engine consumes over a 5k OCI.
Also even though the extended engine replacement warranty expired a while ago, it would have to consume 1+ qt over 1000 miles or something extreme like that to warrant a new engine. In that regard I'd say I'm somewhere in the middle in terms of consumption.
My 02 Camry DD with a 2AZ-FE I4 vvt showed signs of both. But mainly it was the valve seals (blue smoke at startup). So I benefited from high mileage oil. Puffing up and conditioning the rubber seals cut my consumption in half. Going thicker helped with the clogged piston oil hole problem but created the vvt startup noise. How I formed the opinion I posted above. So I went with Mobil 1 High Mileage 10w30 which had the seal swellers/conditioners + its a syn so it also gave me good (enough) flow to quiet vvt noise. She lasted another 150k, died at 345k (exhaust valve broke, trashed the cylinder).
Ive heard a bit of the noise occasionally but i havent had any issues with mine. I change the oil too often simply because I get bored. Im down to two changes per year, im using full syn, 0w20, 5w20 or 5w30. Mostly 0w20 and it purrs on both Mobil 1 Advanced Fuel Economy and PUP. Those are my 2 fave oils for my engine.
Originally Posted By: LeakySeals
Agreed. Toyota and Hyundai I4's seem to suffer from this most.
Really??? Here over the pond we use sae20 oil only for "auxiliary" hybrid vehicles (Prius etc...
Everything else gets 5w30 5w40 10w40....these are common grades here....
I am using 5w30 in Ceed with DPF ONLY because 99,9% of oils here intended for a DPF filter comes in that viscosity....
Been working on Toyota service in 2007-2008......All they had was 5w30 Esso/Mobil 1 (for DPF)
Please elaborate more on that topic.....maybe we will discover that it is just voices in your head (and many others)
I didn't know those were the symptoms to look out for. In that case if I see that problem I will definitely start using a 10W30 HM syn, maybe Valvoline or M1. Thanks! Now I'm not sure if using an oversized filter will help keep the oil cleaner/fresher, but if thats the case I probably will keep using fram xg3600, M1 209A and RP 20-400 equivalents. They fit perfectly with the way the oil filter is set up and many users on the site have confirmed fitment. Bigger filter also means more oil to flow in the engine so that should keep it cleaner longer and minimize the effects of fuel dilution and blowby. Someone correct me if I'm wrong about this.
Never hear any start-up noises on my 2005 Tacoma V6 with VVT-i. Been using Mobil 1 5w30 (recommended viscosity) for most of it's life.
Wondering if some of the start-up noises people hear is caused from the oil filter's ADBV leaking and causing a "dry start".
A question Toyota filters are mounted with the ADBV up am I right? How is the ADBV going you leak up?
