I've got more small engines than I can count. I use conventional rotella 15w40 in everything from my motorcycles to my air compressors and generators.
Cheap,meets JASO for wet clutches and can be found in 5 gallon pails.
Being north of me I am sure you see colder temps. You don't use 15w40 during the winter in your outdoor equipment do you?
No. I wouldn't be able to get it to turn over.
In the winter I buy a 5 gallon pail of 5w30 at Walmart and shorten the drain interval.
My Small engines seem to have a fuel dilution issue. The fuel gets in but never evaporates out in the winter,so I check everything weekly.
I've got 14 air compressors now,an 7 generators,so buying jugs of oil is pointless.
Dang, thought I had alot of stuff.
We've got anywhere from 15-30 hourly rated guys and from 2-4 sub framing crews,and I supply alot of stuff.
I don't want a crew out there pounding nails. Pointless and doesn't make money. I'll drop a compressor and some hose with a couple guns and that same crew doubles in speed,which means we turn over houses faster,making me more money.
They eventually get all their own stuff but in the mean time I need houses finished,so I've got enough stuff to keep the turnover rate consistently fast,which keeps the builders happy and giving me all their houses.
We've also got 2 condo projects and I've already tried using 1 big monster compressor to feed all the site air,and it doesn't keep up. So I put 3 compressors on the floor. No gun runs off more than 100' of hose. Guns shoot faster.
