Oil type
MN
I am considering using one oil/weight in my lawnmowers, snowblowers and three wheel ATV'S. I am considering using Mobil 1 0w-40. Any thoughts on this?
Thanks
That would be fine.
Most here would say to use an HDEO such as Rotella T6 5W-40 or even T5 10w30 for OPE's and 4-wheelers though.
What kind of 3-wheelers are we talking? Is there a transmission on these?
I'd err on the side of an HDEO rather than passenger car oil (eg Rotella T6 5w40, Delvac 5w40, etc.), and it has the benefit of being a bit cheaper than Mobil 1 0w40. But the Mobil 1 should be OK. Most lawn equipment seems to call for SAE 30 or 5w30 these days. My newest Briggs V-twin actually warns against 10w30 in ambients over 80F, but allows synthetic 5w30 at all temps. But I figure synthetic HDEOs at xw40 should be fine now as well.
Originally Posted By: mount
That would be fine.
Honda's. 1985 Big Red 250 and 1983 200S. Book on the Big red suggests 5w30-10w40 automotive oil. No mention of JASO rating to be used. Engine and Trans share the same case.
I was going to go with T6 but found the M1 was cheaper than T6. M1 was a 5qt jug vs 4qt of T6.
Originally Posted By: tig1
I use Mobil 1 10w30 in all my OPE with success.
Think that is what I am going to use. I use M1 in my vehicles.
Rotella 10W30 or Mobil 1 10W30, or Pennzoil Platinum 10W30 or Quaker State Ultimate Durability 10W30, are all good oils for OE.
40 weights and up simply cause the engine to run hotter.
Thinking of trying Pennzoil Platinum 5w30 since been recently getting quite a stash of the stuff, after my Rotella stash gets used up.
Then today received a case of Kendall w/Titanium but its 5w-20.
I have been using Mobil 1 MX4T 10w-40 weight oil in my air cooled engines, but since its so expensive ($11/qt) I will likely switch to a 30 or 40 weight rotella.
I could not justify spending $11 a qt on oil for OPE's. I want to use the best oil for my OPE's but figure as long as the oil is kept at the proper level with regular OCI's, most any thing will work. I have worked on a few small engines where the oil barely registered on the stick and was black as dirt!! This is what ruins engines!!
I've got more small engines than I can count. I use conventional rotella 15w40 in everything from my motorcycles to my air compressors and generators.
Cheap,meets JASO for wet clutches and can be found in 5 gallon pails.
Being north of me I am sure you see colder temps. You don't use 15w40 during the winter in your outdoor equipment do you?
No. I wouldn't be able to get it to turn over.
In the winter I buy a 5 gallon pail of 5w30 at Walmart and shorten the drain interval.
My Small engines seem to have a fuel dilution issue. The fuel gets in but never evaporates out in the winter,so I check everything weekly.
I've got 14 air compressors now,an 7 generators,so buying jugs of oil is pointless.
Dang, thought I had alot of stuff.
