Oil to use in 7.3l 02 PSD
Plumsteadville, PA
Okay, now that I have gotten some info on how long oil could stay in an engine heres the big question!
I currently am running amsoil 15W40 and have 8500miles on it, UOA posted, and I would mostly like not exceed 13,000 miles on it by the time 1 year of it being in hits. So with analysis I could go past the year if the numbers show good or I could just plan on changing the oil once a year. As Pablo said good insurance.
I have been looking at the schaeffer's used oil analysis and they look good, from a cost benefit analysis schaeffer's may be the way to go. What would you all recommend?
Oh yeah as of right now the plan is to auto-rx the truck for 1,500 miles then do a 2000 conventional run and then fill with amsoil 15W40 and see what happens. Truck has 22,000 miles on it approx.
Had a blast driving through slush and ice in the Puget sound today!!!
If the analysis is good, there's no need to change the oil. I've run oil in little-used industrial diesels for several years as long as the analysis is OK.
I like Schaeffer oils. Amsoil is very good, but cost and quality wise, Schaeffer is hard to beat. Also consider Schaeffer Diesel Treat fuel additive.
Ken
My concern was that after a year the analysis may require a change and then the cost of the amsoil does not warrant using it. I will keep on thinking on this one.
Sean
flynavydiesel,look in the used oil analysis section, there is a posting titled Diesel oil anaylsis on Ford PSD posted by 59 vetteman,with a bypass filter the oil should last a long time. there is ALOT of information ,take the time and good reading.
I have been looking at them and that is what got me interested. The only thing that I can not get a good feel of is the amount of time the oil was in use not mileage.
I basically went with amsoil due to the ability of synthetic to keep an engine very clean, but then I found this site and learned about oils I had never heard about. TOO many choices!!! But it gives me something to take my mind off of work.
It is alot of fun and for a bad habit it is not expensive. I use syn oil but I always wonder if it is worth it. My wife has a 2002 powerstroke as well so I follow the posts.
