I was reading the Diesel Truck area and DustyRoads, made the following interesting post. I didn't want to hijack the thread, so I'll ask my question here.
What is the relationship between viscosity, rate of temperature rise and final operational temperature?
It seems a 40 weight synthetic runs cooler and heats up slower than a 40 weight mineral. They may have the same Viscosity at 100 C, but the mineral should have a higher viscosity at lower temps and maybe this heats the oil faster.
Originally Posted By: dustyroads
Most of my trucks from a '97 Detroit to a '12 Volvo had the oil temps regulated at 210 and going into the 230's and 240's pulling the mountains out west. I recently traded in a '13 Volvo that allowed the oil to run up to 246-247 before cooling it. It was free to run anything up that point.
Running 15W40 for three oci's, it would run up there near the cutoff most of the time, constantly hitting the limit then cooling, and then shooting right back up. This was without climbing mountains, just cruising at near 80k lbs.
When I switched to 10W30, it took much longer to hit the 247f limit. It would get there but it took 3-4 times the miles after the cooling cycle compared to the heavier oil.
I then tried Rotella T6 (5W40) for one oci and the oil temps seemed to run even cooler. When pushing it hard in high winds and/or climbing long hills it would eventually get up to 247f to get the oil cooler to kick in but it was the slowest to climb up to that point. Mostly, oil temps remained in the mid to upper 230's using T6.
Obviously for racing and heavy duty you want to run cool. But should maybe short trippers run a slightly thicker (or lower VI) oil to heat things up faster. Given reasonable winter start ratings of course.
