Oil Tech: Valvoline VR1 Racing "Ashless Additves"
Texas & BWI Area
Okay this again is a multi tier question. Here are my baseline assumption(s) & parameters:
A) Internal Combustion Engines, Gas Turbines, etc consume lubricants; rate variable
B) In our street engines, assuming a leak free system, that lubricant infiltrates and exits the combustion chamber causing what I will call "burning."
1)So even if I run a Redline, Amsoil ASL, Premium XXX, etc does the burnt off metal rich (Ca,Z,P) remnants of these leave deposits on the piston tops, exhaust valves, and possible intake valves?
**I know at least for weed-wackers etc you have "ashless oils" added proportionally to the fuel.
Is Valvolines forumulation truly ashless?? Could this be off use to engine that burns 1qt/3000 miles?? Does ashless imply a non ZDDP additive pack?
Thanks! Engine cleanliness is kicker PAO or not
3)
The statement does not exclude additives that may contain ash, only indicates that ~some~ of the additives are ashless. Someone could argue otherwise, but I don't think they are bound to the narrow interpretation.
Think they are referring to ASHLESS DISPERSANT oil additives. They use that tech in aviation oils all the time. No biggie. Just a dispersant.
