Originally Posted By: mechanicx
Oil meeting that spec is Mobil 1 ESP 5W30 and 5W40
These are low SAPs oils with rather low TBN. Normally in other parts of the world this would not be a problem, but the poor quality ethanol fuel that we use here in the US wreaks havoc on such oils causing the TBN to be depleted rather fast, hence, they should not be used for extended oil change intervals. Why then pay a premium price for this oil if you're going to have to change it early?
But if you need a good oil for your modern diesel engine which will not harm DPF, then these oils are a good choice.
