Originally posted by Gary Allan:
The problem is that it's "numb" ..it only reads the average, so the "flow imbalance" between injectors (which others have touched on here) can have you "dumping" in one or two injectors ..while being quite lean in others.
The Ford Fuel Injection book by Charles O. Probst (the one that covers 1987-1993 models and is considered the be THE definitive reference) claims that sequential electronic Ford fuel injection systems can adjust the air-fuel mixture on a cylinder-by-cylinder basis. (Obviously this is not possible with batch-fire systems).
It doesn't go into details, but I can think of at least one way to do it is to vary the pulse width of each injector separately, looking for a response from the O2 sensor. For example, if the computer is compensating for a lean condition, and has increased the fuel injector pulsewidth as a result, it can then start cutting back on the pulsewidth of each cylinder (separately) until it starts reading a lean condition again. Then it can make use of this data to apply a correction to just that cylinder's injector pulsewidth.
Does Ford actually do this (or something similar)? Is the book correct? I don't know--the best way to find out would be to get a Ford vehicle, and a set of injectors, one of which is slightly more clogged than the others.
Install them and drive it around for long enough that the computer can learn those corrections.
Then connect a dual-trace scope to the clogged injector's leads and one of the non-clogged injector's leads, and compare the pulsewidths. If the computer is indeed able to compensate for a clogged injector separately of the others, it should show an increased pulsewidth compared to the others.
I don't know if anyone has ever done this experiment. It would be an interesting one.
