Oil sample taking input . . .?
North Idaho
I need to send in a oil sample to checked for engine coolant in the crankcase. If there is antifreeze in the crankcase in any amount should I wait until the oil is nearly drained or should I take a sample as normal?
Basically does ethylene glycol float [last to drain] or does it disperse through the oil fairly completely?
