Originally Posted By: Bill in Utah
While the chance of having a oil related issue is rare, I think ignoring the legal document called the Owners manual and its recommendations is not too smart.
IF (and a big IF) you have anything go wrong, why give them ANY chance of hassle?
I have been asked for receipts when I had head gaskets go bad in a vehicle that never has those type of problems. They felt if I did not do proper OCI with the correct oil, it could overheat the engine and cause the issue.
But I agree and over the way too many miles I've driven and decades of ownership, oils are excellent! Esp the oils from mid 90s to today!
Take care, Bill
Look out for those flying pigs! I agree with Bill.
( j/k
This pretty much sums it up for me too. While I have never seen a failure personally or through work that I would say was strictly due to the oil itself I have seen failures where using the wrong oil was blammed. My comments over my time here about use the right stuff due to warranty is based on the things Bill talks of.
You have an owner's manual that tells you what is required as far as weight and ratings. Use something that qualifies. If you do have an engine problem and you needed a 5W-30 that meets Chrysler MS6395/GM6094M/etc..., is API certified w/ starburst, and needs to be changed every 6/6000 then that is what you should use and do. Don't use a 5W-40 or 20W-50 that does not meet/exceed the mfg's oil standard and/or that is not API certified to the correct levels. Don't go a year and 50K with your OCI's either.
When I worked dealer parts and service I saw a LOT of engine problems that while not really the oil's fault where blammed on the wrong oil used or improper maintenance( i.e. time frame )and the warranty was not honored( couple challenged but upheld in court ). I posted on here recently in another forum where someone asked about engines replaced under warranty. I talked about my Sister's Impala getting a new engine. Before GM did that they verified she did all of her maintenance and did it on time with the correct oil. Actually, before they pulled it and tore it down to try and find the noise( last step before replacement )they verified the maintenance. It does happen.
While under warranty you are best off to stick to the maintenance schedule and requirements in your owner's manual. Do what you want after but stay with it when under warranty. The oil itself may not be at fault but if you use the wrong stuff and do not change it on time, and then have an internal engine problem, you just might be in for a hard time getting it covered even if the oil itself( other than wrong weight/rating )is not really the problem.
"IF" you are going to stray from the manual make sure it won't bite you in the behind if you have issues down the road. I actually have strayed slightly on my 08 Ram 5.7L w/ MDS BUT my dealer is ok with it and helps me on paperwork. Otherwise I would not take the chance.
I need a 5W-20 that meets/exceeds MS6395 and that is API Certified w/ Starburst. I am required to change it by the OLM or 6/6000 which ever comes 1st. I use RP 5W-20 and I change it every 5K which meets all of the requirements except the API SM/Starburst part. It is still an API certified oil so the dealer is ok with that and knows IF it was going to hurt anything it would be the cat's not the engine. The RP exceeds Chryslers oil spec as well. They do my OC's with my parts but they leave off use customer's parts for me. If they wouldn't do that I would probably not do this.
Use an oil that meets your manual requirements is the most fool proof and safest route bottom line.
