Originally Posted By: KrisZ
Originally Posted By: blackman777
Don't use additives.
They simply aren't needed, especially since oils already have additives.
The synthetic oil will remove the sludge All By Itself without assistance. Just make sure to change it at 1000, then 3000 miles (to remove the loosened-up sludge from the pan).
Total baloney that I see being repeated here to no end. Sure, fresh oil will carry out any loose or soft deposits into the filter or carry it some place else, but it will not clean the engine. Why do people keep repeating this nonsense when there is absolutely no case on record where fresh oil alone cleaned the engine up from sludge or varnish?
Are we counting Mobil's claims that it does?
They show (or showed) it on the page for their 0w-40.
http://www.mobiloil.com/USA-English/Moto...5881d80c1e5af_4
Originally Posted By: Mobil 1
Over time, conventional oils can sometimes form sludge, which can reduce your engine’s efficiency and, ultimately, reduce the life of your engine. Synthetic oils contain fewer impurities and are designed to better resist the formation of sludge, therefore maintaining their viscosity (or ability to flow) and preventing deposits from forming.
Chrysler Sebring Test
In a test using a 2009 Chrysler Sebring that had significant sludge formation, Mobil 1 synthetic oil cleaned up virtually all engine sludge in just one oil change (4000 miles).
That is a marketing claim and what I meant as "case on file" is a record of someone actually cleaning up an engine from sludge and varnish just by using synthetic oil.
Second point, that I raised several times when this claim from Mobil 1 is referenced, is that looking at the before and after pictures I don't see any sludge. All I see in the before pictures, especially the oil pick up tube, is a very dirty oil and possibly in a heavy weight that clings to all the parts. I still see plenty of shiny metal and I definitely don't see any crusty sludge formations.
So, just like with any marketing claim, I do not believe it because we are only shown what we want to see.
