Oil recommendations for 2010 Sienna
Originally Posted By: ARCOgraphite
Oh, I'm a holdout that majority base group iii oils are not synthetic. Given 5w30 is as flawed an oil as 10w-40 (or moreso) the vii addditives will leave quite a mess in the ring area of the pistons and the high detergent bias of a synthetic oil will show some cleaning period "effects" during the changeover. Mobil cautions about this though more at HM older vehicles. I think 20k is PLENTY of hours to coke up the pistons IMO.
So just that I'm clear, using Toyota conventional oil for the first 20k miles, then switching to Mobil 1 will be fine. Although, using Mobil 1 starting now would be even better. Thanks for all the help!
Originally Posted By: tpattgeek
Also, I believe the OEM filter/cartridge is the only game in town for this vehicle, correct?
http://www.amazon.com/Mobil-M1C-251-Extended-Performance-Filter/dp/B001FJICOG
Mobil 1 just started making a synthetic media filter for this engine, but it's pricey. The only other synthetic media filter for this engine is made by TRD for around $12. Unless you're going over 5,000 miles on an oil change, it's probably not worth using anything other than the $4 OEM Denso filter.
